1 - 7 of 7 Posts
ok so i just got an x18 107cc, plug was loose blew out took threads i tried heli coil repair then spark plug broke in head, well i bought a 110cc complete head installed it and when i got it started it started to pop and backfire and if i let it idle it stalls also i saw smoke from the head area what the heck did i do wrong
NO GOOD DEED GOES UNPUNIS
I would suspect its not timed properly or the valves are not adjusted correctly are you sure those are correct
im guessing, the valves as was said, possible proper torque on the head bolts (10ftlbs)
or a missing or damaged gasket or washer
to set the timing you gotta have the T on the flywheel match up with the notch in the head and cam gear
Yup, my vote too for incorrect cam timing...
Since we agree it's timing how do I get to the flywheel I can't get the cover off I took off the surrounding 8mm bolts but cover still feels like it is being held on somewhere
There is a bolt on the other side of the motor if I am remembering it correctly I don't remember which one but try to loosen up one at a time until it tells like its giving more but there is def a bolt on the other side of the motor that goes through to hold it
there are 3 bolts
turn the flywheel counterclockwise till the T
the cam gear cover comes off by the bolt opposite it
1 - 7 of 7 Posts
