1 - 12 of 12 Posts
I just built a polini 39cc wc with 5 port and racing crank, head, and piston and chrome ring was wondering what kind of hp i might be making.
Your head is wrong mounted. Wateroutlet should be on the top where the inlet is.
There must be ring in the cylinder with a small hole that must be on the same place as the inlet and outlet. I've add a picture for understanding.
It's a china copy but at the genuined part you should have the same part.
That transmission is going to grenade so be ready for it.
Take a Pic of the head and the cylinder. It's possible that your head has a small hole on the inlet side like a BZM head. I will take of the head of my polini engine when I'm at home to show you what I mean.
That's correct what kitty says this transmission is not made for the power of a polini engine.
Discussion Starter #12
Mine doesn't have one like that at all. And i was wondering about the flow thats why i put it on like i did but now u sharing this info answered a lot thank you. With a gasket like that it would direct the flow
1 - 12 of 12 Posts
