i just found out there is kart racing about 30 miles from my back door, im gonna go to the next race on saturday and see what they are all about and what i gotta do to get in, gonna have to check out their website and see what i gotta do to be legal to race, i used to race RC cars in california and did well, had first place in the class even 3 months after i moved away and i never once won first place in a race, always 2 or 3 religiously so i stomped everyone in points.
thats weird how the guy who never won a first is first in the class. so im hoping i can win some loot and mainly for me it would be an awesome way to get away from this house. hey CAM2, is that motor i showed you decent enough to race with, in your opinion would it be worth trying to get ready to race in two weeks in the clone division? my old lady is gonna flip when she gets news im gonna pay money to enter this " another one of your junk yard hunks of sh#*'s " into a race that cost about $25 to enter
do you have any suggestions i can do to this briggs to race with it or should i try to get a 5.5 or 6.5 clone? i have 3 of these briggs so naturally if it would compete with the clones id like to use these but need to know the best bang for my buck in mods to get it done quick as possible on a very limited budget. if able to help id appreciate it
With the right mods and carb that engine can be a good contender,,,,on my old runners I used to drill and tap the cases to act as a power breather to get max revs sort of like my homemade headbreather kit for 110cc/125cc superbikes........I used to elongate the intake 3-4" with a PVC tubing to make a place for the barbed ends sort of like my X15
Heres what most people running that class will have done to their engines or part of atleast..If theres a choice between engines and classes id start out in the lower class and build-up a sweet powerplant for the bigger class for the next season
Dual Ball-Bearing, RACING Reinforced Cylinder............
Billet Rod.......
Slotted, Stelite-Faced, Ground Cam w/ Compression Release...........
Dual, High-Silicon Valve Springs........
PVL Digital Ignition System w/7,100 RPM Limiter.........
CNC D-Shape Intake Port,,,,,,,,
Walbro Round - Slide Carburetor,,,,,,,
Dana Fire-Ring Head Gasket......
Racing Crankshaft w/ Induction-Hardened Crankpin...........
Green high flow Air Filter...........
Federal Mogul Moly-Coated Cam Ground, Barrel-Faced Piston,,,,,
Chrome-Faced, Racing Only Ring Package.....
Port-Liner, Exhaust System,,
Mikuni Fuel Pump..
Nora Clutch w/ Quick Change Sprocket Set..
Automotive 3-Piece Valve Retainer System..
Beefy Rocker Arm Stud Nuts..
