1 - 6 of 6 Posts
2WHEELMOTION said:
Just bought a schwinn . Anybody have any pics on how ya did yours??
I did mine like Dai's above but I have problems with the tire valve flexing and hitting the sensor mounted on the fork. I can't log anything faster than 33mph because at that speed is when I believe it hits the sensor. If I put the magnet any further away from the sensor it won't register correctly. Time for GPS I guess. I've always wanted one anyway.
I put my magnet on the rear sprocket. I removed the magnet from the casing using a longer 5mm bolt (peg bolt). Tighten it up and it will force the magnet out. Then I attached it with that strong 3M double sided sticky foam to the sprocket.
1 - 6 of 6 Posts
