1 - 9 of 9 Posts
i ordered a hp carb for my x2 and installed it fine but noticed it came with a intake manifold and gasket i have no clue where it is i would like to know where it is located on the engine ? thanks
Its right where you installed the hp carb. but if they sent you the aluminum manifold it has a smaller bore than the plastic manifold.
Well for the most part yes. But you can bore out the aluminum manifold to 15mm's. It is a better manifold cause it wont crack or the brass inserts wont pull out.
1 - 9 of 9 Posts
