1 - 3 of 3 Posts
hey guys im really stuck on which bike to buy, looking locally only and most lilkely buying from tsunamibikes.com. looking for a race bike either the C2 40cc or G2 40cc or C1 40cc. what you guys think is best stock, and tunned. thanks!
Theyre all basically the same so pickthe design you like.....Just know that bike you choose no matter which one will blow its first head gasket within 10 rides........Its normal and a quality headgasket aswell as inline radiators and water wetter will help keep the heat down aswell as proper tuning
A new engine is a tight engine so abnormal heat will generate and that leads to the premature failure...........heat cycling it a dozen times for 5 mins at a time with a high velocity fan blowing directly at it will help keep the thermal stresses from damaging the head gasket and keep your bike running good and trouble free..........Make sure to give it a couple quarter throttle-throttle burps to clear the jug before shutdown nand let it totally cool down to room temps before the next startup
An infra-red point n aim thermal temp gun will give spot on heat #'s so you know when the engines in the danger zone.............
Dont trust the fluids that come in the bike,,,drain it down and reinstall quality stuff you know....Theres a coolant fill procedure so make sure you abide by it............Good Luck on whatever you chose..............
Thanks man for all that info and help! Very good stuff to know must say, one more quick question do these bikes come with manual clutch? If not is it possible to add it on after? What would that involve? Thanks again!
1 - 3 of 3 Posts
