so the weight left off wouldnt make a difference? also the one has no slot would that still use the tiny key?One is the starter delete go with that
hello😁 if you ever come back i have another question ,,i used the one with the key slot the pull start is catching the pawl but also missing pulling loose..i thought it may be a distance problem because i put this one together from whatever i had left out of 3 engines i added some washers for spacers still doing it going to add a few more see if it makes a difference but any input would be appreciated🤘One is the starter delete go with that
