Will this oil work?
744 Views 4 Replies 5 Participants Last post by  X7 Brap
Hi, I'm expecting my shipment of my Blade 47cc pocketbike tomorrow and I purchased this kind of oil. Will this type mix well to run my bike?
http://www.walmart.com/ip/Super-Tech-Universal-2-Cycle-Engine-Oil-8-fl-oz/16913734?adid=bzv_fb_revshr_001
Thank you.
1 - 5 of 5 Posts
should be fine. Make sure you go through the Air Cooled pocket bike How To's before you get riding.... china bikes are poorly assembled.
Yep make sure to get a tube of loctite green,loctite red,,chain lube,1 gal of 93 octane fuel,,synthetic pre-mix...Mix the fuel and pre-mix to 28:1 for a 4 tank gentle riding break-in regimen after two 10 min heat cycles........
Dnt expect very much performance out of it too,,since 2010 the EPA made the chinese choke these bikes back even more with beehive cats in the expansion chamber,,throttle restrictors and carbs that arent adjustable aswell as very thinwalled steel cheesy frames.
Dont just set it up and ride it,,lube the cables,,throttle housing and chain,,loctite the hardware,,align the reartire,,make sure the brakes are good or adjust if necessary,,heat cycle the engine to max operating temps atleast twice before inducing a load on it to make sure the engine breaks in superb.....
Failure to take the time and go over the bike will resulting in atleast 3 threads made on screws lost and parts that dont really conform,,chain that dont stay on or tight,,crappy engine performance,,leaky carb etc.........
Awesome! lol :thumbsup:
By the way I'm sure that's some of the cheapest oil on the market being from walmart. And it said under the question and answer that it's not synthetic on top of it. So don't be surprised if you mix 50:1 and your engine fails lol.
That's what happened to 2 of my dads chainsaws this year. Cheap pack of non syn oil from the car part store mixed 50:1. I'm not sure how different these motors are compared to chainsaw motors though.
1 - 5 of 5 Posts
