1 - 6 of 6 Posts
There are two little wires coming out from under near the pull starter of your engine when those two wires are connected together it kills it if you unplug those wires and they are open then it will run you can remove the rest of the wiring because it doesn't do anything...
If you want power, the starter/generator housing has got to go, the heavy magnets slow it engine and the extra weight is a killer. Its not that hard to pullstart it. have to have a little mechanics to do that.
Just connect the two wires coming from under the pull start to the key switch
1 - 6 of 6 Posts
