1 - 5 of 5 Posts
For some reason when i start it it warms up and stays running fine but idle is really low. When i take off sometimes it shuts off. If i take off hard it stalls for sure. If i take off slow it goes fine i can top off full speed fine. Then when it come to slow down it will stall?.. Its wierd but idk if its my idleing or what if you have any idea let me know please!
i think its idle and air/fuel adjustments
with it running turn the idle screw clockwise to raise rpms, its the one with the spring
then the other screw gets turned till the take off is good
a whole turn to the right or left (i forgot which way) should help
have you done any maintence like oil change?
Yes i did get a oil change and ect. but the idle isnt different for the throttle i have its the one with the needle and w.e i havent played with them before. And where is the air and fuel screws supposed to be?
1 - 5 of 5 Posts
