1 - 5 of 5 Posts
Hey guys, i was wondering how to put a new chain on my x1 bike... i cant take the bike apart to do that because it is welded together so i was wondering how to do it
you need to remove the rear swing arm, pull the big long mounting bolt that holds the swing-arm to the main frame, then you should be able to remove the chain....
otherwise you will need a chain breaker and some master links <--not the best way but it will work...
Buy a 10ft roll of #415 chain and two masterlinks....Take the old chain and cut it off with a hacksaw...............Size up the new chain,- file or grind it and secure it with a master link........
1 - 5 of 5 Posts
