1 - 3 of 3 Posts
I understand that the govenor controls the rpm of the motor will it damage the motor if i remove it ? whats the worst the could happen ? and how do i remove it ? .
I don't believe there is one, is it possible there is extra "slack" in the throttle cable?
also, have you adjusted the "high speed" needle on the carburetor?
what type of RPM's are you able to achieve?
I dont think I've had a tachometer hooked to that engine before, but 8000+ should be right in there...
it feels like its only reaching 5k rpms and how do i adjust the high speed needle . and how do i fix or check for slack in the throttle cable
1 - 3 of 3 Posts
