Most bikes will and run on the choke only and operate with the choke half open and die when the choke is fully open or the throttle is cracked....Id figure his bike should start with its settings since it was previously running on those settings.
Reason why is when the choke flap is closed it is blocking off more air and introducing more fuel when the engine is cold but when the flap is opened it should run as intended...
If the engine pitch gets higher thats a leanout condition...That means you need more fuel...........click on video below
