1 - 6 of 6 Posts
please can any help i would like to know what oil to put in the transmission of my x1 .the oil that came out was like strawberry jam .any idea ?
my bike manual tells me
"maintain proper transmission fluid levels use 30wt NON-detergent oil"
also
"fill the clutch reservoir located above the chain sprocket. Remove filler bolt. Loosen bleeder screw located toward bottom of engin. fill top oil hole with valvoile 30w NON detergent motor oil part # 265 until oil seeps from bottom hole"
so I filled up both reservoirs with 30w Non detergent oil, I could only find Costal 30w non detergent at the auto zone.
Good luck
also
Good luck
do you think automatic transmission oil would be ok ?
1 - 6 of 6 Posts
