1 - 9 of 9 Posts
Git R Dun PBracer
Have you check the connecter and made sure that it has a good ground?
Git R Dun PBracer
When you checked the ground wires did you use a multimeter?
Yeah, with everything off, put your tester leads between the ground wire and a good ground. If it shows 12+ volts you have a short to ground somewhere.
Git R Dun PBracer
Also you can use a test light. Put the clip on a 12V on the battery. Then poke the test light on the green ground wire at the contoler and at the begining of the light and before and after the connecters. If it does have a good ground the test light will light up. Before you start testing make sure that the test light works.
1 - 9 of 9 Posts
