1 - 8 of 8 Posts
I ordered a hydraulic clutch from ebay for my 110cc x18.It came without and fluids in it and i have no clue on how to bleed it.Help?:confused:and does it matter if its D O T 3 or D O T 4?all help is appreciated.:thumbsup:
The one i bought is exactly the one one the picture.
I'm using this setup on my x18 with my 165cc. If you bleed it good it works great,so far I use dot3 that what I hand on hand. The down side is the master cylinder will break the metal is very cheap! So the best thing is to use a different master cylinder. That's what I did I used an x12 left hand brake master cylinder. I still like it way better than the cable setup much better feel and it seems to allow the clutches to grab better. With the cable setup and motor I run I couldn't slip the clutch at all. Now I can so I can get a good launch of the line.
so i guess not -__-
He can but it wouldnt be the same as your 110cc engine...Swheels has an engine on his bigger than 160cc's with a totally different clutcharm location.............Do a search using pocketbike planets search box..Theres members who have pics of it mounted on their X18 but I will tell you they used the cable holder and the upper clutch case screws with supplied bracket to mount theirs..................Peace.
thanks Cam.. yes Cam is correct! Also you posted in the aircooled pocketbike section. I rarely check the pocketbike section because I don't have one I have a midbike as do you. So when I check this site if I don't see the thread up on the forum catagory site. Then I will miss it as I have done before. I only seen it this time was because it was on the front page of the forums catagory page.
1 - 8 of 8 Posts
