@CAM ur the best bro,
few quiestions.. i already installed the blue cdi, 6 pin plug, only has 5 pins tho... doesnt feel like it did nething at all... i was looking on ebay and one listing said something abouot ac and dc system and to make sure i ordered the correct one,,, "Another test is if the headlights turn on without the engine running, (with just the key on), it is a DC system. In the AC system the headlight requires the engine to be running. Another indication is, if the engine will only run with a battery it is DC. If it will run without a battery, it is a AC system.
Please check wheather you need the AC fired CDI or DC fired CDI for your bike before ordering.
ok my H/L turns on with the key w/o the bike running and my bike will run w/o a battery, so im confused..
also, velocity stack? like extend the intake to the front of the bike like make a ram air effect?
homemade head breather? wht put a lil ait filter on tht nipple on the case? like the filter youd put on the valve cover of a car when u install a cold ait intake?
ok valve lash? soo lost on tht one...
The bikes have a solid state charging system.....The CDI you have is the right one.......The reason why you dont feel a difference is because you havent done any tests and also havent retuned the bike too.......
Everytime you make a change to the way its made totally stock you must alter the tuning to compensate...This is done by tweaking the carb adjustments til the next size jet is needed to feed the need..........
You dont tune it...you wont feel it.........take the stock CDI and put it back in....
take a video camera and point it at the rearof the bike.........rev the bike 10-15 times at all levels,,let it idle,,then punch it to 3/4 throttle from deadstill idle a few times...............
Put the race CDI back in,,,turn the air fuel mix screw 1/4 turn counterclockwise,,,set the c-clip on the mainjet needle 1 notch lower then redo test if the engine is running good............
Then as a 3rd comparison test put the stock CDI back in again and retest the same way again
Put the Race CDI back-in and give the bike a test ride and really wind it out
Watch all 3 vids to see the differences in the way it runs.........
This vid was taken in 40 degree weather............
Theres threads on the homemade headbreather mod.........just put headbreather mod in the search box and check out the threads........
velocity stack............
