Picked up a x18 a week ago. Iv been working on since. The engine was bore dry and missing tons of parts. Swheels and I were working on Monday. Tested the CDI coil and stater. Even swapped harnesses. Still nothing made it spark. We know that parts were good bc he took them off a running x18. So at the very end when we packing everything i noticed that his flywheel was just a hair bigger. Swheel got his mic-meter out and saw that his and afew other 110 motor had a the thickness of 13.xxMM and mine had the thickness of 12.xxMM. His 110 motor that had the starter on the bottom had a 12.xxMM thick flywheel but the top mounted starter engine had the 13.xxMM flywheel. So i swapped out the stater that usex a bottom mouted starter. The pickup on the starter was about 1mm taller than the one that was on mine. Even after the swap the engine still have no fire. Any ideas would be great help.
Thank you.
Thank you.
