x2 speedo prob
2500 Views 25 Replies 4 Participants Last post by  EPR
When I got my x2 yesterday the speedo was unplugged , were do i plug it in at? Plz help
1 - 20 of 26 Posts
Should be a connector on the wiring harness to fit it.
i didnt see any, all of them were taken i think they connected some wires together that dont go together
I have this wiring dia. from SD Scooters, for the early X bikes, find the speedo on it and follow the wires to see where they go.
I still can't find the right plug! Would it work even tho my batterie is drained?
I took all the plastics off and still didn't find the plug it for it
startfrom the wiring harness and eliminate the wires one by one... just follow them to what the are powering.
I looked for all the plugs and there taken (except for the lights), I'll examine it more 2moro
Dont even fret about that crappy speedo....its highly inaccurate..Ditch it..If you want a cheap speedo for under $25 bucks shipped get a Cateye Velo5.They are digital,,programmable and will be a heck of alot more accurate............Good Luck
I have a new one, Cam2 told me its more of an RPM gauge than speedo,lol.
Okay I'll get that then, does my bike need a fuse for anything? It doesn't have one
I would want a fuse 10 amp before my electrical stuff.
Do I need it for electric start?
Yeah if you want to turn the key on and get lights,horn and e-starter aswell as have the new battery recharged through the rectifier/alternator......You need a fuse......
So the bat won't charge without the fuse?
No it will not............The fuse is between the battery and the harness.....
Ok thanks for the heads up, do u no wat size I need for my x2?
Make your own......
cut the wires off the chinese fuse holder
crimp onto the wires two weatherproof female terminal ends
plug one bladetype ATC style 10amp fuse into both terminals to comp-lete the circuit and protect it with a fuse..............
Youre good to go now....................Peace
I was gonna try to pull it from my scooter , I'll be back I'll tell u wat happens,oh yeah don't forget to mail my package out 2moro :p
I dont forget to mail things....I just forget birthdays.........LOL
1 - 20 of 26 Posts
