i dont have anything to grind it down with
You dont have a file or a grinding stone that mounts in a drill chuck?
Putting 2-3 thin tiny washers under the needle c-clip will help give ya more fuel in the meantime but that tab is important to remove...
That tab keeps the float from dropping all the way down into the bottom of the bowl....By restricting the float movement the needle cant drop down in the needle seat far enough to fill the bowl quick enough to feed the demand of the engine when under load
You can also take a small safety pin and open up the pilotjet and mainjeta lil bit to give the carb more fuel...
Anything you do just dont uncork the exhaust mufflers until you get an adjustable carb...........Youll really have running problems
My X22 had a 25mm carb/intake,,racing CDI and internal engine/clutch mods/headbreather mod/hp foam airfilter/modded mufflers/ported head and regorund stock camshaft......It was a pretty powerful and fun ride after the mods...........
