41 - 60 of 92 Posts
<a href="http://s766.photobucket.com/albums/xx304/Dustin8600/?action=view&current=E9DD8439-323A-4136-999A-1117AFAB6B6F-1760-000002C2DAE95C5B_zps0110e0da.jpg" target="_blank"><img src="http://i766.photobucket.com/albums/xx304/Dustin8600/E9DD8439-323A-4136-999A-1117AFAB6B6F-1760-000002C2DAE95C5B_zps0110e0da.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Is this all for lights?
Nope...........Its a starter pushbutton for the starter....
Theyre both for the starter...the orange one belongs to the x22 and the red one an X15/18 or 19...........
Which side does the wire from the starter go to?
Dude that shizz is all fugged up.........
The fat black is your battery ground and belongs attached to a screw on the engine block.......
The red wire without the sheath belongs where the fat black wire is.........There is exactly 1 ground connection on a solenoid...The green wire with yellow stripe and that goes to one wire on the starter pushbutton..the other wire on the pushbutton goes to the engine ground.....When the key is turned on to energize the hot wire and the pushbuttonb is pushed it completes the circuit and activates the solenoid to introduce power to the starter......
The yellow w red stripe needs to go to a switched power source......
That green wire attached to the frame is wrong on the other pic...It should be grounded to the engine........
What color wire is in the yellow sheathed terminal loop attached to the frame bracket?
Where does the black starter wire go and the yellow one with the red stripe where does it go?
Really?????.........Dude now youre just outright kidding with me;- right?????????..Anyone else experiencing the same feeling Im getting out of this??????
Go back to post #49 and re-read what I wrote...if you still dont understand please sell the bike and find a bike that runs already or find a new hobby..........I got alot more better things to do other than keep repeating myself over and over.....
Ive told ya verbally 2 -3 different times in threads #49 and #37 how to rewire the starter system wire for wire so if you cant comprehend then I gotta bow out before I say something thats gonna get me banned...................Im done ,,,,,GOOOOOD Luck yo
Think the green plug is your CDI box, the blue and yellow might go to your stator coils or your coil. Are them red wires from the 2 prong plug going to the 3 prong charger plug on the frame or to your battery. My X18 has a black & red charge the battery in storage plug.
Where does the black starter wire go this bike is more of a project then I ever thought it would be Craigslist ad said 20 minutes and it will run. Clearly that's a joke.
Where does the black wire start and where does it end. Power goes to the key on the dash. Then over to the starter button. Key on, press the button power should go to the starter solenoid and turn on the Ign, so the engine turns and the coil fires. Here is an X18 full wiring dia. It should be real close. Follow what your looking for a wire at a time, don't try to understand all the wires at once, you will go Crazy, lol. These might help you.
Does this look right the red wire on the right is grounded to the frame. The red on the left goes to the battery (positive) the black is the starter wire.
Is this a okay spot to use for a ground (only the things that have to ground to the engine) the black goes to the negative on the battery am the green is soldered to 5 other wires.
What is this plug? one wire (blue/white) is soldered to one goes to Gage's I think the other goes to plug on top of the engine case. The yellow goes to Gauges I think. The red/black goes to a the plug on top of the engine case. The yellow/black goes to starter coil and the black/white also goes to gauges I think.
41 - 60 of 92 Posts
