Reed block vs Blast box ?
2K views 19 replies 4 participants last post by  cutlasskel
i would do those mods 1 at a time. just cause if there is a problem with them, you usally dont know wich one has a problem and then you tinker with the wrong one. good mods though. ive never heard about a "mikobu carb".
well you can buy the bw reeds and take the reed out of the bw, and take the rear 2nd reed out of the 4 pedal system and use the other 4th reed from the 4 pedal system and put it in the bw, incase something happens to the 4 pedal system. kind of confusing, but it helps seal of the gas/air tight mixture.
try a 66mm jet. is your bike really modded? list your modz. a 68mm might be a wee bit big.
