Is the Dellorto SHA 14mm ( CLONE ) Carburetor good
  • Yes
    Votes: 2 33%
  • No
    Votes: 4 67%
41 - 60 of 64 Posts
I hate society today, I've had some neighbor call the cops because I was riding in the road in the complex I live in, which is usually next to no traffic. Cop showed up and questioned me and the bike. I explained it was fully electric and he was like oh okay, have fun! I purposely continued to ride it in the neighborhood to piss off whoever the crybaby was.
During the peak of popularity it was fine you could build a few engines for maximum power and get enough guys/gals together to cone off a parking lot and have a stock, modified, and unlimited class and spend a day racing sometimes even Seattle PD would come around and enjoy the show...
Nowadays you can't even fire one up in your own yard without some Karen standing at the fence holding a phone with 911 on the line...
I guess you live in a horrible area. It's it's not legal around here but 911 does not show up every time we fire one up
There is always people like that. Police like to pull me over a lot on my Electrics. Funny thing is mine are only supposed to be a Max of 20 mph in my area but they don't know when it looks stock that my next to does 24 or 25 mph. And they don't even know the right laws. Sometimes I have to educate them. And I do the same thing, ride by the Karen's over and over and over and over again. Eventually they'll get it that I'm doing nothing wrong. And then I take my gas bike by them. And if they don't like that I take my really loud car which is totally legal by them. That's all you got to do sometimes wake them up to the reality that they're wrong, and yet those were the people that were blownin off fireworks on the 4th of July at 12 a.m.. lol
Discussion starter · #49 · (Edited)
I've managed to find a kit like this, I noticed there is a hole in the manifold to set it up with the check valve etc. Will I need to drill a hole in the Reed block to suit???
Only if you have done heavy porting 98% of the time there is plenty of vacuum in front of the reed block to drive the pump
If you do decide to do the mod there is absolutely zero room for error you have to fill the Old Port with JB weld and then drill the New port well the glue is still soft using a drill press.
Like I said before this mod is really risky and gives you absolutely zero additional horsepower and should only be done if you can't get enough fuel when you back out the high-speed needle passed the spring the mod will also dramatically shorten the life of the pump inside the carburetor 😂.
I did this mod on my high torque mini quad engine that I built Then I only needed it because I did an anti para mod on the piston which tends to make it lose some vacuum then there really was no need because I had to detune the engine anyway because the stupid mini quad is a piece of junk and it speed wobbles all over the place at those speeds and gets really dangerous to ride lol
Discussion starter · #52 · (Edited)
Anyone know where to find the non return valve for the walbro View attachment 160714
That's a fuel filter and a vacume F the fuel filter acts as a mini tank so you don't have to return to the fuel tank 😉👍😏 I got both parts from O'Reilly Auto parts.
You can also use a vacuum T if you can't find a F
I'm using my phone atm and the pages are jumping about and not loading correctly, I'll fire the laptop up later and read up on what was posted earlier in this chat about the working of the carb etc. My parcel came today but they sent a piston and barrel kit for a goped instead of the correct part
Discussion starter · #55 ·
That's not how these carburetors work.
The carburetor pumps fuel all the time it is powered by a vacuum port inside the intake manifold.
Any of the fuel that it pumps that is not burnt is returned back to the fuel tank.
I did not want to drill a hole and run a return line all the way back to the tank for no reason at all when I can just have it simply returne to a closed loop.
It could use a one-way check valve but it works fine for me and does not affect the performance of the engine in any way.
Finally got the walbro carb kit, obviously Chinese because the casting had a hole in the casting next to the fuel inlet.... Pouring fuel out of it 🤣🤣🤣 JB weld sorted that out. My only issue is the throttle sticks open as there isn't any return spring on the throttle body, I'll work something out today, but it's back to running good again and it seems to be easy enough to set up the fueling 👍
41 - 60 of 64 Posts
