Is the Dellorto SHA 14mm ( CLONE ) Carburetor good
  • Yes
    Votes: 2 33%
  • No
    Votes: 4 67%
61 - 64 of 64 Posts
Newbie question here, is a 17.5mm carb an upgrade to a 14mm across the whole rev range? (This would be on a 40cc liquid cooled 3 port BZM engine). I read 14mm can be better for low end running (less bogging before the WAHHHHH!), so good for short tracks where you are accelerating out slow corners a lot? Thanks!
Discussion starter · #64 ·
Generally you will sacrifice high-end power for low end torque BZM bikes are dynoed for optimal power across the entire band and the gearing should be changed for the different tracks not the carburetor...
61 - 64 of 64 Posts
